Skip to content
General System Tweaks
1. CPU mitigation’s
A public speculative execution attack exploiting return instructions (retbleed) was revealed in July 2022. The kernel has fixed this, but it results in a significant performance regression (14-39%).
The following CPU’s are affected:
  • AMD: Zen 1, Zen 1+, Zen 2
  • Intel: 6th to 8th Generation, Skylake, Kaby Lake, Coffee Lake
Check which mitigation’s your CPU is affected by using:
Terminal window
grep . /sys/devices/system/cpu/vulnerabilities/*
Disabling mitigation’s
While disabling the mitigation’s increases performance, it also introduces security risks.
Add the following to your kernel command line: retbleed=off or to disable all mitigation’s: mitigations=off
Edit the appropriate file to make the changes persistent:
  • GRUB: /etc/default/grub
  • systemd boot: /etc/sdboot-manage.conf
  • rEFInd: /boot/refind_linux.conf
For more information:
Downfall
Downfall is characterized as a vulnerability due to a memory optimization feature that unintentionally reveals internal hardware registers to software. With Downfall, untrusted software can access data stored by other programs that typically should be off-limits: the AVX GATHER instruction can leak the contents of the internal vector register file during speculative execution. Downfall was discovered by security researcher Daniel Moghimi of Google. Moghimi has written demo code for Downfall to show 128-bit and 256-bit AES keys being stolen from other users on the local system as well as the ability to steal arbitrary data from the Linux kernel.
This affects the following CPU generations:
  • Skylake
  • Tiger Lake
  • Ice Lake
Disabling Downfall
Add gather_data_sampling=off to your kernel cmdline options. mitigations=off will also disable downfall.
2. AMD P-State Driver
For improved performance and power efficiency, you can enable the AMD P-State EPP driver. The default AMD P-State driver may not provide the same benefits as the acpi-cpufreq driver.
Add one of the following options to your kernel command line:
  • AMD P-State: amd-pstate=passive
  • AMD P-State-GUIDED: amd-pstate=guided
  • AMD P-State EPP: amd-pstate=active
You can switch between modes at runtime to test the options:
  • Autonomous mode: platform considers only the values set for Minimum performance, Maximum performance, and Energy Performance Preference.
    Terminal window
    echo active | sudo tee /sys/devices/system/cpu/amd_pstate/status
  • Guided-autonomous mode: platform sets operating performance level according to the current workload and within limits set by the OS through minimum and maximum performance registers.
    Terminal window
    echo guided | sudo tee /sys/devices/system/cpu/amd_pstate/status
  • Non-autonomous mode: platform gets desired performance level from OS directly through Desired Performance Register.
    Terminal window
    echo passive | sudo tee /sys/devices/system/cpu/amd_pstate/status
3. Using AMD P-State EPP
To use the P-State EPP, there are two CPU frequency scaling governors available: powersave and performance. It is recommended to use the powersave governor and set a preference.
  • Set powersave governor: sudo cpupower frequency-set -g powersave
  • Set performance governor: sudo cpupower frequency-set -g performance
To set a preference, run the following command with the desired preference:
Terminal window
echo power | sudo tee /sys/devices/system/cpu/cpu*/cpufreq/energy_performance_preference
Available preferences: performance, power, balance_power, balance_performance
Benchmarks for each preference can be found here: https://lore.kernel.org/lkml/20221219064042.661122-1-perry.yuan@amd.com/
4. AMD P-State Preferred Core Handling (enabled as default)
AMD Pstate driver will provide an initial core ordering at boot time. It relies on the CPPC interface to communicate the core ranking to the operating system and scheduler to make sure that OS is choosing the cores with highest performance firstly for scheduling the process. When AMD Pstate driver receives a message with the highest performance change, it will update the core ranking.
This can result into a better performance and process handling. More information here: https://lore.kernel.org/linux-pm/20230808081001.2215240-1-li.meng@amd.com/
The AMD P-State Preferred Core Handling is now enabled by default.
You can use the following command to check if your CPU supports it:
Terminal window
cat /sys/devices/system/cpu/amd_pstate/prefcore
or
Terminal window
cat /sys/devices/system/cpu/amd_pstate/status
to see if it is enabled
5. Disabling Split Lock Mitigate
In some cases, split lock mitigate can slow down performance in some applications and games. A patch is available to disable it via sysctl.
  • Disable split lock mitigate: sudo sysctl kernel.split_lock_mitigate=0
  • Enable split lock mitigate: sudo sysctl kernel.split_lock_mitigate=1
To make the change persistent, add the following line to /etc/sysctl.d/99-splitlock.conf:
For more information on split lock, see:
